cya level in pool dropping
Bozer4
50
Manteca ca
Hello, My CYA level in my pool dropped from 40ppm to 35ppm over a 3 week period, is this normal? It has been hot out here, averaging between 95 and 105 degrees for multiple weeks, so I'm sure there's a lot of evaporation. I'm using liquid instant conditioner by Natural Chemistry. It's been a consistent loss, I've lost 10ppm over 6 weeks.
Thanks, Brett
ajw22
29,811
Northern NJ
Pentair Intellichlor IC-60
40 CYA vs 35 CYA (which is not a valid reading that you cannot measures) is with in normal testing variation.
CYA is not lost in water evaporation. CYA does degrade by chlorine and high water temperature.
Losing 10 ppm in 6 weeks is not something to be concerned about. Just add 10 ppm of stabilizer.
Bozer4
50
Manteca ca
You're right, sometimes differentiating between 40 CYA vs 35 CYA can be difficult because of the disappearing black dot with the CYA test. I wish they had a test for CYA that had color changes like all the other tests. My pool temp has been between 80-85 degrees and free chlorine 5-7 so I guess that's where I'm getting the degradation of CYA. Thanks for the advise, I'll add 10 ppm of liquid instant conditioner and call it good.
Brett
Bozer4
50
Manteca ca
I forgot to mention that my pool has an automatic pool refill system. I understand that CYA is not lost in water evaporation but wouldn't CYA level drop due to city water replenishment from pool refill system?
Brett
mknauss
44,895
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Brett
No. Unless it is refilling due to you draining water from the pool.
There is natural degradation of CYA in water primarily due to elevated water temperatures.
Reactions: wireform
ajw22
29,811
Northern NJ
As water evaporates the CYA level in the remaining water rises. CYA stay behind when water evaporates. Then when you add water to refill the CYA level returns to what it was.
Jason245
90
Fort Lauderdale FL
Wow.. and I thought I was crazy when I started seeing my CYA drop.
So basically I will lose about 10PPM CYA a month with ~80-85 degree water?
ajw22
29,811
Northern NJ
Chem Geek discussed the various ways CYA degrades in this thread ...
Jason245
90
Fort Lauderdale FL
Just take our word for it then.
I have been taking the word of people on here like it is the gospel of pool science... if you told me that on the 12th day of the 12th hour of the 12th minute of the 12th second of the 12th month if the moon is full, all the water magically moves from the shallow end to the deep end creating a tsunami... I would probably make sure everyone was out of the pool and wearing rain coats and had camera's ready.
  • Haha
Reactions: frogabog
