CYA in cold water
chuck9997
24
Tennessee
Hello.. how accurate will CYA readings be in very cold pool water? I wanted to get a head start on things... so I've been getting the water pretty clear and trying to keep a safe amount of chlorine in the pool. Water is still very cold... last night's overnight low was 28. Anyway.. I put a fair amount of stabilizer in the pool last week... but my CYA didn't seem to be coming up. I thought maybe my testing regeants were bad... so I ordered a new kit from TFT kits. But.. CYA today is still almost 0. Would cold water affect the reading?
kellyfair
4,602
Tampa, FL
Intex Krystal Clear
How did you add the CYA? I usually wait a couple of days after fully dissolved before I test, but of course my water doesn’t get nearly that cold.
kellyfair
4,602
Tampa, FL
Intex Krystal Clear
All fully dissolved? When did the sock go empty?
kellyfair
4,602
Tampa, FL
Intex Krystal Clear
You didn’t mention the actual water temp, did you? I would take the sample inside and let it warm up a bit, then test.
Reactions: chuck9997
