FC 10 (raised due to CYA..need to raise more)
CC 0
CYA 140 (ugh!)
PH 7.4
TA 80
CH 200
SALT 3800
So I had my CYA at 80 and life was good. FC started being lower than normal so the next time I tested CYA and got a 60 result I figured that explained the FC problem. I put in PoolMath that I wanted to raise CYA to 80, it said add 21 oz so I did. Tested CYA it was 100...reading on the forum I learned to dilute to get the 50% reading. Did that yesterday. The result was 70 so really 140!
How in the world did 21oz get me in this trouble? Even if CYA was at 80, to get to 140 PoolMath says I would need 64oz.
I moved onto a 2nd bottle of the CYA test at the same time could something be off with those (I know....I'm probably grasping).
I really don't want to drain the pool but I guess I'll have to. The hubs is going to say "you need to hire a pool person" I can feel it coming.
CC 0
CYA 140 (ugh!)
PH 7.4
TA 80
CH 200
SALT 3800
