I last tested my CYA one year ago in April, it showed 60 and has held at 60 since I started using the TFP method for 2 years now. I keep a very detailed log for my records and the FC has not been below 6 ppm at any time this past winter and usually I run it around 8 ppm during the hot Arizona summer.
I thought perhaps it was my test kit and tried it twice using older and newer chemicals, I also took a sample to the local pool chemical store and they verified CYA at 0.
I know it's common that if the FC reaches 0 during the winter that CYA is known to go to 0 but this is not the case with my pool. I will admit I have let the PH level rise above 8 most of the months that I haven't been swimming but otherwise we are very good about keeping the FC levels up.
Here is where I stand as far as levels:
FC 9.0
CH 600
CYA 0
TA 120
pH 7.6 (I just added MA yesterday but this is usually 8.0 during the winter and a constant battle to keep it at 7.6 all summer)
I was told at the store that the TDS was at 5000, not sure if that comes into play.
This water has been in for 2 years now and I have done nothing more than use liquid chlorine and muratic acid, no tablets or any other chemicals.
Any suggestions are certainly welcome, thank you.
FC 9.0
CH 600
CYA 0
TA 120
