I have been struggling with cloudy water and no chlorine due to a combination of shutting off the pump for a couple of days to fix a leak, followed by my pump going bad due to a power brownout. So, I shocked with 3 bags of shock, only to find out there was no free chlorine the next morning. Then I used 6 bags, again with no chlorine. Last evening, I dumped 9 bags in, and woke up today with no chlorine.
So, I read up on the SLAM method and am trying to keep adding chlorine bleach and shock today to keep the level up. I just decided to check my stabilizer level. It has always been in the 50 to 70 level every year once I get things going, never had a problem. Today, the test shows 0 stabilizer. Did my CYA really disappear? Was it eaten by whatever is consuming my chlorine?
I'm off to Wally World to buy stabilizer, something that I've never had to do. I read about the sock method, so I guess I'll do that while still adding bleach every hour or two.
ps. I know you will ask me to post a full set of readings, but I need to head to the store right now. I just checked and my PH is 7.5, but my chlorine is at 10 despite dumping enough shock and bleach today that it should be at 40.
