Hi, all.
Last year, when I had my pool installed, I was "blessed" with the installation of an Aqua Smarte auto-chlorinator (basically a different brand of Pool Frog with the Bac Pacs). Since joining up with TFP, since they saved my skin, I've taken any cartridge that was in it out and have never used it since.
I do have a question, though, about adding CYA through that little gizmo.
Can anyone think of a reason not to utilize that device to add CYA to a pool if you're not using it for any other purpose and if I were to simply drop a sock with the appropriate amount of CYA in it, tied off, into the chamber and crank the water throughput to full throttle? Would that not function essentially the same as suspending the sock in front of the return, for all intents and purposes?
I wanted to ask here before I launched into my experiment.
Thanks!
Thanks!
