Going into my 3rd full year with my in-ground plaster pool. First 2 years everything was normal, then last summer the PH started going crazy. It goes up to over 8.0, I add a gallon of muriatic acid to bring it down to 7.7 or 7.8, and then 3 or 4 days later it is back over 8.0. TA stays in the 100-110 range, but have to use baking soda to keep it there since I'm adding about a gallon or more of acid every week to keep the PH down. The first 2 years PH was stable and used a gallon of acid every few months. The acid is expensive and now I'm using almost as much acid as I am chlorine! It's a 35k gallon pool with spillover spa and I've been testing with a ColorQ tester with fresh test chems. Nothing has changed that I am aware of. I'm at wits end and grasping for any ideas about why this is happening and how to fix it. Any ideas would be greatly appreciated.
