I got my new pump plumbed in today. After looking and thinking and looking and thinking, I couldn't see any way to get it to come together the way I had drawn. It would have taken skills beyond what I have. As it is, I feel like this just barely came together.
I ended up mounting the diverter valve vertically. Because I added the recommended straight-pipe length at the front of the pump, it ended up further back than the original. If I had mounted the valve horizontially, as I had planned, the control box would have been in the way. So I went vertical with the valve and brought it higher. I intended to make it the same height as the input to the multivalve. I missed by a little bit, though. Having the union at the input to the valve help because it means this pipe can rotate to match the one from the diverter valve.
I also added the hose bib to this pipe there at the front.
I'm a bit worred about the elbow towards the middle. That's sorta the capstone piece that I added last. I'm not confident that either pipe got fully seated in the elbow though so it might be the weak connection.
I've got an electrician scheduled for Tuesday morning to connect up the pump. I can't test out my plumbing until then.
I still have the pressure return for the cleaner to connect there on the right. The new pipe coming from the diverter valve is a bit higher than the existing pipe towards the front. I think I'm going to attempt to raise the exiting pipe (cut, add a coupler, and more vertical pipe) and try to match the new one from the valve.
I don't think I've gotten any two pipes to come together the way I intended.
Does anyone have a resource for how to get pipes to align better? How do you align a new run to a pipe that is already fixed in place? I keep measuring, but always seem to be slightly off. Sometimes I can make it work, but several times I had to redo it.
