Crack in newish mini-pebble
dalstrs
14
Grapevine, TX
Hi all, I was just scrubbing my pool since the weather here warmed up a bit and found a crack along the edge of the bench in my pool. The pool was replastered with mini-pebble last Feb-March, so I think this should still be under warranty. What would cause something like this? I plan to call the company that did the replaster but wanted some advice on what I should be asking for as far as remediation and some ideas of what could cause it.
6XSBChamps
178
Longview, Tx
update on here with any developments. I have a crack on my bench after only 6 months. The PB says its a check crack and not an issue. I am watching it closely. 1 year warranty would be up end of June.
dalstrs
14
Grapevine, TX
I can't see the Gunite through the crack due to the angle/ light but it looks like it might be deep enough to hit the gunite. Hopefully, it's not the substrate. When they replastered I don't think they did any substrate repairs in that area and only minor stuff around the rest of the pool.
Z
Zmann
I agree that crack is probably all the way thru to the gunite and needs to be addressed even if it is just for cosmetic reasons
if your old plaster did not have that issue I would say the drama from plaster removal and may have fractured the gunite at that lip
so they should do exactly what Aqua-Holics suggested
MAPR-Austin
In The Industry
Feb 23, 2021
41
Kansas City, MO
I'm going to go against the trend here...that looks like a 1"x1" highlight tile, is that correct?
If so, you're probably looking at 3/8"-1/2" thickness delaminating from the vertical surface of the step. That's the thickness of the plaster finish.
Can you take something metallic - maybe like a butter knife - and tap/drag on a different area of the pool and then on the area below the crack? See if you can make out any hollow sound.
My guess is some kind of dust or contaminant prevented a good bond there. What kind of prep did they do on the old surface before replastering?
ajw22
37,969
Northern NJ
Pentair Intellichlor IC-60
There is no such thing as a “check crack” in plaster. That is a concrete term as concrete will crack. Plaster should not crack. Don’t let your builder blow you off with that BS.
AQUA~HOLICS
In The Industry
Jul 19, 2021
691
Southern California
Yes it can be repaired but it will most likely not match perfectly to the surrounding plaster. The deeper in the water the repair the less it will be noticeable and you may be the only one who knows. It’s still not to industry standards in my opinion and that alone would have me demanding it be corrected.
dalstrs
14
Grapevine, TX
A small update. The pool company finally had someone come out today to start repairs. It looks like it separated a good way down the wall. Still haven't figured out what the cause was, but I don't see any cracks in the substrate. I also found a few tiles that were cracked in line with the coating above them.
dalstrs
14
Grapevine, TX
They didn't seem alarmed. It's fairly common that the ground shifts here (north TX) and my pool is older. According to my pool guy, it seems to be random around here. He said his pool shifted and cracked 6 months after it was built and after they fixed that it hasn't cracked again in 15 years.
6XSBChamps
178
Longview, Tx
Thanks for that info. I'm in Longview Tx so it's similar soil. I have a crack in my plaster that I'm watching closely and I lose sleep over the worst case scenario that the shell could be cracked and that would mean catastrophic things. Best case scenario, poor plaster job. mid range, ground moved, shell cracked but can be fixed if needed.
Casey
12,759
SW PA
Fiberglass
Jandy Aquapure 1400
That patch is very close in color to the original. Wow. They did great in color matching. Hopefully it will withstand the test of time.
Reactions: kimkats
