so 2 years ago bought a house with a 16x32 inground with sand filter one skimmer and one bwottom drain. I run it 50/50 while opening. with the depth pools about 22k gallons . last year i opened and just winged it ... this year trying to get it clearer faster.
opened it started filtration brushed whole pool and shocked .. probably too much .. 6 lbs of granular shock .... tested levels after 12 hours overnight running pump
i have a small test kit(HTH 1273 6 way test kit) which i used and ..
PH is off the charts haha prob >8.5.. water was bright pink and normal range is light colored
Chlroine was was over top reading .. which is bright yellow ... my chlorine test water was orange
total alk is 70
i also put in 12 lbs baking soda and have floater and disperser in skimmer with 2 3" tabs each ... just threw in robot this am .. pool is a light green hue from VERY dark green when cover was removed ... OBVIOULSY folks who closed it know NOTHING !!
my main question is where should i go from here ? clarifier ? more or less chlorine? ph reducer? or leave it ?
Thanks in advance im still new to this but someday ill be opening a clear pool i hope
total alk is 70
