Could someone look at my bid and offer HONEST feedback please
mknauss
44,888
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
You have 0 leverage with that contract. A 10% hold should be in place until the project is completely turned over to the owner.
TXPfamily
18
Pflugerville, TX
Autofill means the pool has a water line plumbed to it with a float valve. When water level drops due to evaporation/splash out the autofill system automatically adds some water, maintaining a constant water level. The alternative is to manually put a garden hose in the pool when the water level gets low. Some folks in hot, dry areas report having to add water every few days. This can also be a problem if you're on vacation and the water level drops below the skimmer as the pump will then start sucking in air instead of water.
What does the autofill usually run as far as $??
Jimrahbe
23,546
Bedford, TX
T,
Makes sure you are getting the IntelliCenter that comes with the internal SWCG power center, the IC40 plus two valve actuators...
See this link... Pentair IntelliCenter i8PSIC40 Kit - Pool and Spa with Load Center and IC40
The only thing that I saw was pretty minor.. The IntelliCenter does not use "ScreenLogic" but it does come with a similar built-in system..
Have you ever been in a gunite spa before?
TXPfamily
18
Pflugerville, TX
T,
I've been in several spas, but really could not tell you the difference??
cowboycasey
8,648
Southern OK
CircuPool SJ-40
the only thing I would change is the money payment.. The last payment should be after the project is completely done.. right now you have NO leverage if the plaster is a disaster or they do not finish the pool.. they will still have major work to do and the pool will be paid for... they can leave you in the wind...
