Corrosion resistant check valve?
Rodex
123
Mansfield, TX
CircuPool Edge-25
My waterfall slowly loses prime and I’ve changed out just about everything in the path besides disassembling the pump. I am now pretty Dang sure it’s this 17288 check valve - I can now hear flowing/leaking when the pump turns off.
Why would this need to be a corrosion resistant check valve? I’d like to get one of the ones that you can change the valve out without having to cut PVC (any suggestions?).
ajw22
24,850
Northern NJ
Pentair Intellichlor IC-60
A Jandy check valve has a rubber flapper and is corrosion resistant and rebuildable.
Reactions: Rodex
imrodee
1,050
Waxahachie, TX
Pentair Intellichlor IC-40
I have a spa spillway and a grotto waterfall. The grotto waterfall (furthest from the equipment) will start dribbling, then stop altogether when I need to backwash or clean the filter. You might check that.
Reactions: Rodex
Rodex
123
Mansfield, TX
CircuPool Edge-25
Searching INYO, looks like in the size I need (1.5”, 2 lb spring) has a lot of CMP options but not Jandy. Amazon listings are sparse. Any other sites to check out?
ajw22
24,850
Northern NJ
It is a crazy time for pool equipment availability.
An equivalent CMP check valve should work if you can’t wait until Jandy is available.
hwy17
157
Northern California
I have heard it claimed by a pool service tech that the magic plastics CR2 is even more corrosion resistant than the Jandy/Pentair/CMP. Only the Jandy comes in 1-1/2" though.
ajw22
24,850
Northern NJ
Reactions: Rodex
Rodex
123
Mansfield, TX
CircuPool Edge-25
Looks like CMP has one -
CMP Check Valve 1-1/2" Inside 2" Outside 2 Lb. Spring - 25830-704-000​
Yeah the CMP one seems to be the only one readily available. I can wait - I just have to run the waterfall pump for a bit longer every day to reprime, which I’m sure puts some strain on it, but it’s been a champ through the beatings I’ve given it the past couple years.
