Correct amount of chlorine for a salt water pool?
Bosqueboy
48
Amherst, VA
While web surfing the other day, i found a site that recommended 0.5 ppm chlorine for a salt water pool. I'm having a little trouble understanding why a salt water pool would require less than the normally recommended 1-3 ppm. Anyone have the answer? I've always set it to 3 ppm and now wonder if I'm overdoing it!
Bperry
1,902
Knoxville, TN
CircuPool RJ-60
If anything, your probably under-doing it. 😉
proavia
3,438
Chandler AZ
CircuPool RJ-45 Plus
Without knowing what your CYA level is, there is no way to know what your FC level should be.
How are you testing your pool water? Add your test kit(s) to your signature.
Post a full set of current test results from one of the recommended test kits.
FC
CC
pH
TA
CH
CYA
Salt
Water temperature
Reactions: BowserB
BowserB
708
"Old" Katy, TX
Pentair Intellichlor IC-40
What Emily said. In addition, the test for CYA is a bit subjective, and it's hard to not look at the tube and say "that's too high, I think its nn." Accordingly, I use the TFP SWCG FC chart but use the FC minimum and target for the next level of CYA. My CYA recently showed as 70 (3-5ppm), but I use 4-6ppm as my FC standard. I feel like running FC a little high makes it more bacteria and algae resistant, and I really don't want to have to SLAM my pool.
