- Jun 20, 2016
- 9
- Vinyl
- CircuPool RJ-60
I am changing from liquid chlorine to CircuPool RJ-60 PLUS Salt Chlorine Generator. Needed to raise salt from about 750 to ~ 3500 in my 24000 gal in ground pool. Normal clean filter pressure = 17psi. After adding two 40lb bags of pool salt, pressure rose to ~ 24psi. I did backwash before adding salt. After ryunning pump for 24 hours straight, pressure dropped to ~ 21psi. I still have ~ 10 - bags to add. Is this pressure too hi? How can I get this salt added without such a huge increase in pressure? Should I backwash again?
