Controlling a Valve Actuator Remotely
JSpool3
7
Gilbert, Az
Is there an electric valve actuator that can be switched easily with applying power on/off to the actuator to switch the water flow direction? I would like to control the actuator remotely from a wireless Z-Wave switch, maybe by switching on/off the 110VAC power source (or 24 volts actuator voltage). It seems the actuators like the PE24VA uses an electric switch on the actuator (no remote control) or the Pentair Intelli-value requires expensive automation for remote control.
Jimrahbe
12,665
Bedford, TX
PG,
When the relay is in the closed position, the valve rotates one way and when the relay is in the other position the valve will rotate the other way..
Just to be clear, the OP would have to control just the relay with his Z-whatever, the circuit itself would have to get constant AC power to run the transformer..
Rich D
268
MA
I have been wanting to do something like this since I opened my pool, However I was under the impression the actuator had some type of position sensor so when it reached the end of its throw the controller would turn off the power to the actuator so it would not keep trying to turn the valve. From Jim's schematic it appears it is the actuator alone that determines the stop point and stops turning the valve.
So in my use case It is the waterfall valve I wish to control. It is a three way valve that will return water to the in floor cleaner or the waterfall. The best setting for my water fall is to only turn the valve approx 1/4 of a turn from the 'waterfall off' setting.
Can a actuator for a three way valve be controlled with the same simple circuit? IE - have a three way valve only turn 1/4 turn ?
Thanks, Rich.
Jimrahbe
12,665
Bedford, TX
Rich,
Manually, you can put a three way valve in any position you want... An actuator will only rotate the valve from one stop to the other...
Inside the actuator, you can adjust the position of the stops so you can set the valve to turn to whatever position you want.
Rich D
268
MA
Rich,
Ahh, That's the exact answer I was hoping for.. That project is going back to the top of the to do list.. Thanks for the very specific and easy understand help Jim....
Pool_Medic
In The Industry
Apr 1, 2018
768
Bangor Maine
Not sure I understand but you can adjust the stops on the actuator to only turn as much as you want.
Check out the Hayward Omni, it’s made just for this type of situation. It can control a pump, SWCG and 2 actuators remotely.
atttech-2
1,184
Central Valley CA
The valves do have stop points controlled by cams and micro switches. Jim's diagram is correct, the relay either feeds voltage to red or to white 100% of the time so the motor is always trying to go in one direction or the other only the micro switch in the valve stops it. Lets say that the relay closes to the red side when its energized. As soon as the relay is turned off the valve will start to swing the other way until it reaches its stop point. This can also be accomplished with a WiFi sprinkler controller they are already 24 VAC so it should work well with a JVA. THIS is an old post with a diagram very similar to what Jim posted
atttech-2
1,184
Central Valley CA
Least expensive would probably be a 120V WiFi switch connected to a 24VAC transformer. If you shop around I would think you can get everything you need project box, WiFi switch, transformer, and wire for around $50
Jimrahbe
12,665
Bedford, TX
You do NOT want to turn the 24 VAC on and off.. You only want to turn the relay on and off..
atttech-2
1,184
Central Valley CA
ah Jim is right I forgot one leg needs to stay powered at all times, sorry about that. So you will have to throw a relay in the mix like his original diagram so figure an extra $10 for that too
Rancho Cost-a-Lotta
800
Rancho Cucamonga, CA
Thanks. I have an unusual set up controlling programs on my VS. It uses mechanical timers, a low voltage switch, a 24 volt transformer, and an Intellicomm Interface Adapter. With the exception of a low voltage switch/controller, I may have what I need to integrate a single actuator into the mix. I'll start a new thread when I'm ready.
JSpool3
7
Gilbert, Az
js,
Build yourself a circuit like the one below to drive a standard Jandy valve actuator. Then use your Z-whatever to turn the relay on and off...
Thank you, Jim. This is great, just what I was hoping for. Appreciate your feedback, along with the others who responded.
Just to be clear, I would need to get find 110 VAC WIFI switch and have that energize a relay that would switch the 24VAC. Does anyone have a suggestion for a good outside relay that is energized by 110VAC and can switch 24VAC (power to the actuator)? A link or P/N ?
Or as Attech-2 mentioned could use the wifi switch in a sprinkler system that is used to switch 24 VAC to sprinkler valves. Very clever. I don't have a WIFI sprinkler system, but maybe there is a "component" available I can buy that is used in a WIFI Controlled Sprinkler product? Does anyone know of a P/N or link to a WIFI 24 VAC switch?
Thanks to all,
JSPool3
98119
Jimrahbe
12,665
Bedford, TX
js,
Other than the smoke and fire.. your diagram will work perfectly.. :mrgreen:
You need to change the 24 volt relay to a 120 volt relay..
I know nothing about the WiFi switches, but my guess is that you can't switch the neutral wire like you are doing.. You should wire one side of the 120 volt relay to neutral and then switch the 120 volts through the WiFi switch.
  • Haha
Reactions: Don_TLR
JSpool3
7
Gilbert, Az
js,
You need to change the 24-volt relay to a 120 volt relay..
thanks Jim.
Yes, agree. Need to update the drawing to clarify. The relay is a 110 VAC relay switching the 24VAC power. The Wi-FI switch, will be switching the hot side (black) of the 110 VAC. The white wire of the 110 VAC would not be switched and connect directly to the step-down transformer and the relay.
JSpool3
7
Gilbert, Az
Here is an updated diagram.
Sort of miss radio shack. Jim, by chance, do you know where is best to buy a 110V relay that will switch the 24V, 1-2 amps? Be best if could take some weather, but I might be able to put it in a weatherproof box. Ideas?
JSPool3
98131
Other Threads of Interest
