My pool is four years old and i have had the PH issues for awhile, we have a 8' spill way from the hot tub to the pool that runs with the pool runs. I believe this contributes to my issues.
I am adding 32 oz of acid every other day to keep my PH below 7.8. Currently my TA is around 60 I try to keep it a tad lower other wise the PH rises even faster. As you can imagine, with all the acid i am have to add around 2-4 lbs of baking soda a week as well. I was told if I premix the acid and water in a bucket prior to adding to the pool it would help with lowering my TA and it has worked quite well.
I am considering trying borates to help stabilize my PH swings thoughts?
My Numbers are as follows: FC 3.5, PH 7.7, TA 60, CH 250, CYA 40
