Unfortunately, I don't have all of my test results on hand [my pool is in my second home in the mountains and I am in my primary home until Monday]. But my CYA has been sky high since I opened the pool a few weeks ago. A suggestion was made here to drain the pool and I kind of parked that idea while messing with my test kit. Now it looks like that's what I have to do. Bearing in my mind that I have an inground, vinyl pool, I now see that "floating my pool" is a real danger. But I think I have to drain it because I can't seem to get the CYA lower.
The pool was "closed" by some spa guys who didn't really explain what they were adding to the water. They drained half the pool and added some chemical. They told me that when I opened it, I should pump out the deep end water while adding fresh water to the shallow end. This made no sense and on this site, experts agreed. But I guess whatever they added is screwing up my tests and has contributed to my high CYA.
I thought I had logged my test results in my Pool Math app...but they aren't there. So I can't leave all my results. I will do so on Monday when I'm at the pool. Until then, trying to understand if draining is what I should do? And, more importantly, we've been swimming in the pool all along with these CYA. We're not dead...but should I keep everyone out until I figure out the CYA?
The pool water is clear by the way. Lovely, actually.
The pH is 6.0
The pH is 6.0
