Hi all,
After using our Intex 15x48 pool last season we're considering installing a permanent (or whatever it's called, I mean, everything is temporary in life right?) above ground pool. One with rigid walls.
There are a few concerns of mine regarding this.
First, my understanding is the pump circuit must be on a GFCI. Can I use a 20A GFCI receptacle mounted at the house and wire the pump circuit into the GFCI side of that? This would be the easiest solution for me and I'm hoping it doesn't need to be a dedicated circuit to meet code.
The location we had our 15' Intex pool is fairly level, within 1/2 an inch or so. We didn't use sand, so I'm assuming I would need to dig down a few inches to fill in with sand so it doesn't wash out and re-level it. How deep does the sand have to be? How do I keep from leaving foot prints?
Do most locations require bonding of the water? Does a bonding connector have to be used or would a bonded stainless steel ladder work?
Finally, are there any preferred brands? Looking for a 15'x54". Does anyone sell a deck for these anymore?
