Moved from here: How big should I go?
Hi MK.... I am in Vegas and considering switching to SWG. Your response above sounds like there can still be daily (or near daily) chemical testing with a SWG in order to set the SWG rate (time & %). Did I understand that correctly? It's easy to understand the upside of SWG but I want to make sure I really understand the maintenance requirements if I move to a SWG. There is always some downside besides the initial cost I would guess.
The 3 ppm number is a median number. Your pool may be less or more. We typically say a pool will lose 2-4 ppm FC per day in swim season. So you will need to test your FC each morning (or at least several times per week) just before the SWCG starts generating for the day as that will be your lowest FC in the pool water for that day. Keep the amount you test at that time at or above your Target level based on your CYA.
