My old in ground pool is being renovated. I have an old single speed pump and a Pentair IChlor30 chlorine generator (connected to Pentair control box on wall, connected to timer). I want to install a Pentair SuperFlo VST pump. Does the VST pump have an output for the chlorine generator? I haven't found a wiring diagram. If not, I guess I have to find a way to sync the two. I already have to make changes out there because I don't have GFCI breaker feeding yet. The system is 115 volt.
Thank you.
Lou
Thank you.
Lou
