Confused if valves are on
Ryan2409
4
Las vegas
There are two valves on my pool. Should they be pointing to sky and off towards the ground.
ajw22
24,903
Northern NJ
Pentair Intellichlor IC-60
Welcome to TFP. Hope you stick around even after your problem is solved.
They are off in the pic. Handles vertical pointing either way will block the pipe.
Turn the handle 90 degrees to turn a pipe on.
Ryan2409
4
Las vegas
So they both need to be turned 90 degrees? The one on the left side is labeled rear hole. The second one is not labeled though.
Ryan2409
4
Las vegas
ajw22
24,903
Northern NJ
The pics in post #4 show the pipes open.
This is the diverter that is in the valve. The diverter is opposite the handle. When you move the diverter in front or a pipe it closes it.
Ryan2409
4
Las vegas
The pipe in the left of the picture is labeled “rear hole”. The pipe of the right is not labeled. So should that be turned at 90 degrees as well?
JamesW
24,112
Notice that it says "Off" on the wide part opposite of the handle. That wide part matches the diverter gate inside the valve.
ajw22
24,903
Northern NJ
We need to have details of your pool and see complete pics of your equipment pad to try and guess what those pipes are for.
