Can you run your hand on the underside of the PVC and find water?
Could be a single leak near the flow switch using the pipe to travel to both locations.
Run full throttle and see if the unions are dripping. When i hooked up my equipment this year, I though I was good until I went to vac and raised the RPMs.
