Complete DIY concrete pool
jvaymd
11
Cresaptown, MD
So after months and months of work I was finally able to fill our new inground pool. I did not subcontract any of the work out. The pool is concrete with standard white plaster. Though the pool is (obviously) incomplete I wanted to get it to the point of it being filled and used for the last few weeks of warm weather. I am looking forward to getting the coping installed and starting to put our yard back together. I believe we are going to use Eagle Bay Paver "Jefferson" for the coping. I haven't settled on what I'm going to use for the decking yet. When all of the grading is complete the goal is to have patio around all sides of the pool; I have a lot of dirt work to do yet. There is a ton of things I would have done differently simply because of not knowing better; though right now I'm just happy its holding water. Take it easy on me pool pro's!20200820_192358.jpg
YippeeSkippy
14,579
Evans, Georgia
WOW! You did all that yourself, huh? I'm impressed! I see one skimmer... how many returns?
Please fill out a signature line (under settings) with information about the pool, its equipment, sanitation method, testing, etc.
Maddie
Reactions: jvaymd
Dirk
6,854
Central California
Wow, awesome!!!! Usually "DIY" means you just hire the subs instead of paying a PB to do the same. But you really mean DIY! Congrats. Keep the pic's coming as you progress.
I see lots of toys. Kids I presume. They must be stoked. There's your reward. Nice job.
Thanks for sharing... and welcome to TFP!
Reactions: jvaymd
jvaymd
11
Cresaptown, MD
Maddie
To clarify, I am a general contractor. I used two of my employees to help on the concrete pour days (and my kind father in law) and a few collective days with doing the plaster and plumbing; though I truly only had help for 7 various work days through the project.
It took me forever and a day too. I started clearing and basic grade work for the pool in late February of this year. That timeframe would never fly if I was paying someone to do it, which, believe me, I would've loved to have been able to just write a check and watch the work from the comfort of my home.
I will upload some more pics of the project at various phases here shorty; I'm going for a swim!
Dirk
6,854
Central California
Geez Louise. Right. I didn't put that together. It wasn't just a "simple" dig a hole and fill it with a pool job. Wow, you don't mess around. You had to build the whole pool out of wood first, then a second time!! Yikes. Did you pour the floor later? How does that get tied into the walls (not seeing any rebar in the pic)?
Reactions: borjis
jvaymd
11
Cresaptown, MD
I did pour the floor separately. I did a 10'' grid of #3 rebar pinned into the already poured walls. I also put steel mesh on top of the rebar grid. I chose the same concrete mix specifications (aggregate size, psi, etc.) as was used on the walls for the floor. There was no practical way for me to form it for one pour. If I could have hired a gunite or shotcrete crew I would have considered it, but no one in my area really does it.
Reactions: Dirk
Dirk
6,854
Central California
Cool. I really like your giant edge tiles. Haven't seen anything like that before. Less grout, more filling! ;)
Are you planning to continue on here and take care of the water ala TFP?
Reactions: jvaymd
jvaymd
11
Cresaptown, MD
Thank you in regard to the tile choice. They are supposed to be pool/outdoor rated and "impervious" to freeze and thaw cycles and resemble Carrera marble. We ran two courses of the blue, beveled edge porcelain tiles to add some color.
Yes, I am planning on taking care of the water the TFP way. We are just starting to get our bearings in regard to water testing and the recommended chemicals.
