Hi,
I have a pool and spa running off one variable speed pump. My spa has a spill over feature which I have to run to allow for the water in the spa to circulate. Referring to the attached pic how would you recommend the return valves be positioned for optimal return to pool and spa? I'm not sure if one should be opened more than the other.
Thanks.
Dan
Dan
Thanks.
Dan
Dan
