Hey guys ,
first things first lol FC about 18, CYA about 45 PH 8.5 TA 20? ( get to it below)
moved, house has 24 ft above ground pool, just got into opening it. Had to drain most of it because they had CYA of well over 100. I drained 95 %, refilled. everything ”looking “ good , but cant get chlorine and PH in line. Dumped GALLONS of liquid into the pool only to have it eaten up in a matter of a few hours, dumped almost an entire bottle of Muratic so far, and still 8.5 and wont budge. The water was crystal clear, pool bottom and walls were clean as a whistle, and i was stumped, then i pulled those rickety birthday cake stairs from the wall and looked into the large hole into the back into the abyss, and what looked back was scary! It was filled i believe with mustard, it was yellow green, and just disgusting. I started with shoving a vacuum head in there, then a brush, still not satisfied i took the vacuum hose, shoved it into the breathe hole in the stairs, and held it to the jet to pump chlorinated water deep into it and flush it out a bit which seems to have worked, i figure at least this will get fresh water in there with chlorine. I have dumped gallons of liquid and am having trouble getting up to mustard slam FC , and the PH wont budge! Ive never dealt with this beast before, have been lucky with my old pool and now here we are lol. my plan tonight is as follows unless you have better advice ( which is what I’m looking for please)
1) keep adding liquid until i finally get it to mustard slam (24?) keep filter going nonstop
2) forget about PH until chlorine is dealt with ( is it the algae keeping it high? Is it that drastic?)
3) once i get a good overnight , try and work on PH
4) then work on TA
Any help you guys can give I appreciate, this site is always so helpful you guys are always there for each other , thank you in advance!
4) then work on TA
