Coleman pool inlets
hpycamper
5
Cambridge, MN
I purchased a used Coleman 24’ x 52” pool and want to hook to a sand filter and skimmer. There are two small rubber nipples that are in the side of the pool, I believe they’re for the skimmer. I am going to install a Hayward skimmer and need to close these two small rubber inlets permanently. Anyone have any ideas on what to use to plug them? They are soft rubber so they will be able to be clamped.
CT-Steven
205
CT
Intex Krystal Clear
I opened the hole up to 1.5" and used these:
You may be able to use this
hpycamper
5
Cambridge, MN
I figured it out. I got 3/4 in caps at the hardware store and used waterproof glue and slid them in and clamped them. They were too low on the pool to cut for my skimmer. All sealed up now. Thanks for the reply!
Golfnjunkie
1
Gkoucester, Va
The 2 holes are for water return, they are not for intake on the coleman pool. The one, higher nipple on the left should be connected to the intake/skimmer side of the pump.
