Moved from here.
I'm in the same boat here with my pool, cloudy water despite mostly solid numbers? 10k gallon vinyl pool, just replaced the liner in the spring and filled with fresh water. It's been solid all summer until the past few weeks where it's now murky/cloudy. This happened two weeks ago and I backwashed ~5 inches of water and replaced while adding more bleach which seems to have fixed it for a week or so. Now I'm back to the same issue and can't seem to get it clear.
CH 130
PH 7.6
TA 70
CYA 50
FC 10
CC 0
Not sure what is wrong at this point, possibly the filter just not doing it's job? I've noticed each morning if I run the vacuum the bottom appears to be dirty as the path the robot makes is clear, if I didn't run the vacuum I wouldn't have been able to tell as the liner is fairly dark.
CH 130
PH 7.6
TA 70
CYA 50
FC 10
CC 0
