Cloudy Water
Locster
17
Missouri City, Tx
Been brushing the spa and tanning ledge weekly and would see slight green film in the water. Get a lot of pollen in the pool from the jungle in the backyard. Lost 1.5ppm FC last night from 6. Is the slight cloudy water a sign of algae growth or the pollen? Do I need to SLAM or add higher FC level than 6? Thanks.
Latest test:
FC 4.5, PH 7.6, TA 80, CH 300, CYA 50
mknauss
43,661
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
With your FC drop overnight I would suggest you take the FC to SLAM level. Pollen will collect on the surface but typically does not consume all that much FC.
