Cloudy Water Coming Into Pool From Jet
spacerobot
Active member
Aug 1, 2019
26
New York State
I had an issue with my pool this week. It had been a little cold over the last week so we weren't swimming. I had the cover on. I noticed a couple days ago the water was seriously cloudy. I shocked the pool and that did the trick. Pool is clear as can be now. All chem levels are reading good. I was in the pool and noticed the jet circulating water into the pool looked like it was putting cloudy looking water into the pool. My thoughts are wondering about my filter. It is a cartridge filter. I just got the pool in July of last year so the filter itself isn't even a year old. the filter was cleaned before closing last year. It's only been open this year for about a month so far. Looking at the pressure gauge it is reading 15 PSI. Do you recommend taking it apart and cleaning the filter again or could it be something else?
mknauss
50,326
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
What was the clean pressure for the filter?
What are your pool water chemistry test results?
spacerobot
Active member
Aug 1, 2019
26
New York State
I took the filter out earlier. It was pretty dirty and full of junk. I cleaned it down with a hose and it looked white again. Once I turned everything back on it did not look so cloudy coming out. I'll keep an eye on it and see how it goes.
