goodyFH
Active member
Apr 6, 2021
30
Auburn, KY
Backstory: Bought house with pool in January. Got it going good with yalls advise. I bought a stenner pump and a drum of chlorine. its been going good.
I go on vacation last week, i thought i had plenty chlorine in the stenner but i was wrong. Got home saturday to a very green pool.
I poured a bunch of chlorine in and the next day its not green but very cloudy.
So ive been adding at least a gallon everyday and its still cloudy, i actually got out the tablet holder and put it in there with 4 3"tablets in it
I read where it could be the ph, so i got some muriatic acid today
My test results when i got home from work were:
FC - 0 , last night it was around 10
pH - above 8, 7.5 after adding half gallon of acid
so i add 2 gallons of chlorine to shock, now my readings are:
fc - 11
ph - 8ish (i read its not very accurate during shocking)
TA - 140
CH - 100
CYA- 30ish
I have 14000 gallon above ground with sand filter
What should i do???
I havent tried brushing walls or floor, but it doesnt seem dirty just cloudy but that could just be ignorance
goodyFH
Active member
Apr 6, 2021
30
Auburn, KY
So this what i gathered...
-Take tabs out
-check chlorine levels multiple times a day and add to shock level, would morning, lunch time, 5ish, and then 10ish be good?
-i have a robot vacuum, should i run it now?
-basically its gonna take a week
What else?
Newdude
11,232
NY
Take tabs out
Check (y)
2 hours is best. The more you ‘M’aintain the quicker it goes. Do the best you can of course.
Sure. Brush and vac/robot daily. More if time allows.
Many times yes but all pools and particularly their filters are different. First you kill the crud and then you wait as the filter removes whatever didn’t dissolve.
What else
Lower PH to 7.2 with MA. If you are really high above range it may take more than one add to be back in range.
Backwash the filter at 25% rise in psi.
keep reading the slam guide.
ask away with any thoughts. :)
goodyFH
Active member
Apr 6, 2021
30
Auburn, KY
How’s your filter? Is it clean? I don’t know much about sand filters but I read people need to occasionally replenish or replace the sand.
filter got cleaned out and new sand beginning of season so i think it should be good,
i backwashed some earlier today and it was clear. does that mean i didnt backwash long enough?
goodyFH
Active member
Apr 6, 2021
30
Auburn, KY
Check (y)
thanks, i can do most of that i believe. 2 hrs wont happen during day due to work but i live close enough i can come home for lunch and possibly one other time throughout day
goodyFH
Active member
Apr 6, 2021
30
Auburn, KY
Matter of fact the original PH in post 1 probably isn’t that high because of the 11 FC. Sorry I missed that until now.
ok cool, i added a quart at lunch around 230 today and it got it down to about 7.8-8 then another quart after work brought down to 7.5ish before i started heavy with the bleachy stuff
