I did an ascorbic acid treatment on my pool on Saturday per the instructions I found here. Stains cleaned up nicely and after 24 hours I started working on balancing everything out. Added washing soda to bring up the ph and added liquid chlorine to the minimum for my CYA. The only thing that was still low was the TA and I was planning to pick up some baking soda on my way home. Last night before going to bed I turned the SWG back on but at a lower than normal level. I'm at work now but my husband just called me and said that when the pump turned on the pool got all cloudy.
Any idea why the water is cloudy? Did the chlorine react with the ascorbic acid? Not sure how to proceed or if it will just clear up on it's own.
