Cloudy green pool STILL
CV701
21
Wisconsin
Hello and thanks in advance!
So we have a 24x52 summer waves pool that we bought last year. This was our first season opening and we did not properly close it last year. A mistake I will not make again. Anyway, after opening, the pool was extremely dark and could we not see anything. We leaf raked and got all large debris out, dumped shock in (blindly-before I found TFP) and then turned original cartridge pump on.
As you can imagine, the water did not change much. I then found this website which has been amazing. I purchased the Taylor k2006 test kit and went from there in preparation to SLAM.
First day readings were
pH 7.1
TA 120
CH 60
FC 12.5
CC 1.5
CYA 20
We then added stabilizer per the pool calculator. From what I understand, we don't really need to raise the calcium hardness.
Second day readings we only tested FC (which went down to 8) CC(which went down to 1-yay!) and CYA (40).
Per the SLAM/CYA chart we added chlorine and raised the FC to 16 and CC is still 1.
The problem is the water is still cloudy green. I can only see about 18 inches down. I'm rinsing the filter multiple times daily and run it 24/7.
There does seem to be a lot of very small particles in the water. I know flocculant is a no no but will clarifier help? Will it even be effective while SLAMing?
What do I do??
CV701
21
Wisconsin
I just updated it. It's about 13k gallons and a 2000gph cartridge filter pump. No skimmer, although we just about the Hayward through the wall, it's just not hooked up yet.
CV701
21
Wisconsin
So update. It is day 9 of SLAM and my pool is still green.
I'm ready to throw in the towel.
From day 1 before SLAM
pH 7.1
TA 120
CH 60
FC 12.5
CC 1.5
CYA 20
Brought CYA up to 60. My SLAM level for FC is 24 and have been keeping up with that testing the water at least twice a day, more if I am home. Being so desperate, I even put more chlorine than necessary just hoping it will kill the algae. I don't know how the water is still green.
Please help me.
mknauss
23,036
Laughlin, NV
Well if you have been holding SLAM level FC for 9 days, your pool should not be green still.
Have you been running the pump 24/7? Cleaning the filter when the pressure rises by 25%? Brushing at least daily?
Mr Bruce
2,438
Greenville, SC
I agree. Cloudy I could understand, not green.
How many total gallons of chlorine do you estimate you have added to the pool. Can you post what the FC is everytime you test it and how much chlorine you add to maintain your SLAM level?
zea3
11,768
Houston, Texas
When did you bring the CYA level to 60? How many times a day are you testing and bringing the pool to slam level?
CV701
21
Wisconsin
On days that I work, I test it at least twice. Otherwise I test it about 4 times a day. One morning I tested it was 18, that was the lowest it has gotten. The last few times it has only dropped to 21. I always add more chlorine than what pool math says so it doesn't drop too much while sleeping or at work.
I run the pump 24/7. It hasn't been off in 9 days other than cleaning the filter which I do daily. I also brush once a day. I do not vacuum because I cannot see the bottom. I have leaf raked and there is nothing left coming up.
CV701
21
Wisconsin
In total, I have probably added 4 cases of 12.5%. 4 gallons in a case. I brought CYA up on the first day. The pump I have does not have a pressure gauge.
mknauss
23,036
Laughlin, NV
If water cost is not extreme, I would suggest a significant water exchange to fresh. Something beyond regular algae is going on.
CV701
21
Wisconsin
There have been times that I check the filter and the return jet is very slow, almost no flow. So I clean the filter and it returns to normal flow. Maybe that could be contributing?
CV701
21
Wisconsin
I have well water. We filled the pool last year, half off the well and half with a water truck but that was pricey. I could possibly drain half the pool. How would you suggest directing the water flow while draining?
mknauss
23,036
Laughlin, NV
Your post about no flow from the pump is concerning. And looking at your equipment, the filter system is not adequately sized for the pool. Did that pump/filter come with this pool?
CV701
21
Wisconsin
No the filter did not come with. It said it was rated for over 15k gallons and my pool is about 13k. It is much faster and stronger than the original pump but the cartridge seems to clog quickly. I clean it at least once daily. Yesterday I did twice.
mknauss
23,036
Laughlin, NV
The filter is your issue. If the pool never got algae, it will work fine. But not with the swamp you have.
You need a larger filter/sand filter or you need to drain most of the water (leave at least a foot of water in the pool) and fill with fresh and SLAM that. Then you might have a chance.
Only way I see you will have success.
