Cloudy Gas When SWG is On?
GigaMike
19
Albany NY
This is my 2nd year with my SWG and I dont remember this at all last year. When the SWG cycles on, the returns emit this cloudy water that kinda looks like it could be the chlorine gas the SWG makes. Im not sure if this is normal or not. I just added new salt this morning and I know you are supposed to wait 24 hours before using the SWG but I wanted to get the system working again and get some chlorine in the pool. I can reply tomorrow after its been 24 hours but for now the SWG is turned off. When the cell is off, no cloudy emissions.
PH 7.6
TA 80
CYA 50
FC 2
mknauss
23,544
Laughlin, NV
When the SWCG is operating it creates small bubbles. Mine do not look quite that strong, but I run a VS pump at low rates.
Normal.
jkayca
76
Ottawa Ontario
I had the same problem this year when opening. Lots of bubbles causing the pool to turn cloudy when the SWG was active. It went away eventually. I was thinking it maybe that the water was pretty cold when I started up.
