Closing soon, chemistry suggestions
mmesqc1578
105
Chicago, IL
Pentair Intellichlor IC-40
Closing pool in two weeks. What is an ideal level to get my fc at for closing? I finished SLAM a week ago, so that's why my fc is high right now.
FC 9.5
pH 7.4
TA 110
CH 450
CYA 50
I have an autocover and SWG, so was going to try to keep my CYA at 50 or 60.
Texas Splash
33,857
Fiberglass
CircuPool RJ-45 Plus
Many people will take their FC to about SLAM level a week of so prior to closing. For you that would be 20. That would be one final blast of chlorine to ensure organics are eliminated while allowing time for the FC to fall a little before closing. Many up north have had unusually warm weather, so that additional FC could be helpful.
Reactions: mmesqc1578
mmesqc1578
105
Chicago, IL
Thanks. Typically, what percentage do you want to let fc fall from slam level before you officially close? I can just use regular clorox bleach from Walmart yes? I ran out of liquid pool shock.
Texas Splash
33,857
Fiberglass
Yes, Walmart's Great Value laundry bleach or their Pool Essentials (if in stock) will work. If you decide to increase the FC to 20 (SLAM level), you can close at any time really. The excess FC level won't hurt anything. If you elect to let the FC fall prior to closing, to add Polyquat 60 for example, then allow the FC to fall to about half of SLAM level (10 or so). Too much FC will just eat-up the Polyquat.
drrayb
3
toronto, ontario
the how-to article on the site recommends polyquat. Is polyquat 40 ok? Also, can it be added with FC above 10?
Final question, I don't expect it matters whether I use liquid chlorine or cal hypo for this, if calcium level permits?
Thank you!
mmesqc1578
105
Chicago, IL
A pool industry professional mentioned he uses a chlorine slow release floater throughout winter. Would this be a good idea as insurance? He also said recommends Enzyme release floater. Could this be helpful to open to clear water in spring too or just overkill?
