- Sep 8, 2018
- 53
- Vinyl
- Pentair Intellichlor IC-20
I've attached a diagram of my pool.
Planning to close tomorrow. I've adjusted chemicals, brushed and vacuumed today, should be in good shape to close tomorrow for chemistry. I had a couple questions about blowing out the lines. Specifically the best way to clear the lines.
I have an Air Supply Cyclone blower.
Will the following plan work? Any better ideas?
Thanks
- Shut down system, open air valve on top of filter.
- Open filter housing, remove filter media.
- Closer filter housing.
- Drain water from pool to below the skimmer (but above the returns).
- Connect cyclone blower to Skimmer
- Position first 3-way valve so that the system is blocked, and the skimmer is open to the main drain.
- Run blower until main drain is blowing air, close 3-way to airlock the main drain.
- Run the blower through the system from the skimmer to the waterfall feature
- Switch the return 3-way to now blow out main returns
- Plug returns with threaded plugs
- Cover and pray
Thanks
