Close but no cigar
wireform
In The Industry
Aug 15, 2017
3,319
Spring Valley, NY
What I have here is a 24500 gallon vinyl pool with the following #s:
FC=5
CC=.5
PH=8.2
TA =100
CH=275
CYA=40
I'm not sure where to go from here with the PH being high. What chemical agent can I use that won't effect anything else
I probably can afford to drop my TA some and help myself on the PH issue. But once I reach my TA level what can be used to bring the PH down without my other #s changing. Pool gets used a fair amount with lots of splashing of which I'm assuming brings up the PH. I don't have any water features that add to this problem. Thanks in advance, Allan
mknauss
44,915
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Re: Close but no cigar
Lower your pH using muriatic acid. Use PoolMath to determine amounts.
Only lower to 7.6. When it gets to 8, lower to 7.6. Your TA will come down and unless you are adding high TA fill water, your pH will stabilize.
wireform
In The Industry
Aug 15, 2017
3,319
Spring Valley, NY
(Not the pool in my signature)
FC=5
CC=.5
PH=8.2
TA =100
CH=275
CYA=40
:confused: I'm not sure where to go from here with the PH being high. What chemical agent can I use that won't effect anything else
