Clear, brown water, HELP!!
jkmitch0826
2
Hi. i am a newbie, just bought an intex 18' x 48" easy set pool. i need some guidance. i didn't do much research before hand, silly me :)
We have well water. after filling, i added a 3" chlorine tablet in the floating canister late last night. This morning the water is brown, but crystal clear. i am going to get a good testing kit this week, i only bought the ph, bromine and chorine one.
Does this sound like iron to you? If so, what's my next step? i will probably also take a water sample to a pool store tomorrow, but you sound like a very knowledgeable pool guy!
I will also be buying the 3 B's tomorrow!
i look forward to hearing from you.
oh. the ph & chlorine levels were in the "desired" range on the test kit. (ph 7.6 & chlorine 1.5)
Thanks for any advice!! jessica
:cool:
JohnT
Admin
9,476
SW Indiana
Welcome to TFP.
It sure sounds like iron.
The easiest solution from a pool maintenance perspective is to have water delivered, but that's not always available.
There are products that can bind the metal to avoid the symptoms, but no practical way to remove it. Here's a link to an article on Metals in the Water and Metal Stains that may help.
Bama Rambler
23,063
Welcome to TFP Jessica. :wave:
As JohnT said, sounds like iron to me. A good test kit is a good place to start and reading the link that JT provided is good advice.
The test kits that we recommend (see my sig) don't test for metals so your best bet is to take a sample to a pool store near you that can test for them. Don't buy anything they recommend until you come back here and post the numbers so we can advise you on what you need.
If it is metals and you have access to metal free water you will be ahead to drain and refill with new water. Otherwise, you'll have to use regular doses of sequestrant to keep it in suspension.
anonapersona
2,598
I've got a question... there are carbon filters that you can get at Walmart in the RV section... would those filter out iron?
257WbyMag
5,061
Denton, TX
I don't think so. A greensand filter will pull a goodly amount of iron and other metals out, but they typically won't get all of it.
Bama Rambler
23,063
The problem of filtering out the iron is one of magnitude. It's one thing to filter a few hundred gallons for drinking, but a completely different animal to try and filter an entire pool. Reverse Osmosis would take care of it but I'm not sure where the breakpoint would be between using sequestrant and running the water through an R/O treatment even if it's available in your area.
jkmitch0826
2
Thanks for all of the helpful information!! if it is iron, can someone recommend a good sequestrant?
I will also check into having water delivered....
Also, will the iron hurt anything? or is it just unsightly?? after all, this is the water i bathe in and cook with every day!
Bama Rambler
23,063
Any sequestrant that's HEDP (Hydroxyethylidene-diphosphonic acid) or phosponic acid derived, are the ones most commonly recommended here as being the best.
The iron won't actually hurt anything. It just makes your water brown and will stain your liner. The biggest reason for getting water free of iron is so that you don't have the continual expense of adding sequestrant.
Kias
664
NW Ohio
I did the exact same thing last year with my 12' easy-set. It was fine when I filled it up from my well, and then the next day... Brown and clear. I purchased a bottle of HTH Clarifier from Wal Mart and added, I think, about an ounce. Just follow the directions. I then cleaned the woefully inadequate filter that came with the pool about every 4 hours, and it was cleared up in about 4 or 5 days! Piece of cake!
Then following the awesome advice you get here on maintaining the water my pool looked like this for the rest of the season!
