Cleaning up a 2 year old pool - holy moly!!!
Casey
11,934
SW PA
Fiberglass
Jandy Aquapure 1400
Hi Kamil! Excellent job on clearing the pool. With more filtration and POP, you'll be crystal clear in no time! :goodjob:
PharmerAnthony
45
Southern California
You've come a long way! You wont believe the pride of ownership you'll have once that pool is sparkly clean and your friends and family come over and marvel at your cystal clear water. It'll definitely be worth it, and you wont believe how easy it will be to maintain. I just took my pool over and shake my head at how easy it is and ask why I paid someone to maintain it for me!
I found some old pictures of the pool... this is how it was when I first started to SLAM it.
http://s103.photobucket.com/user/kamil-g/slideshow/Pool
Kamil
45
Lancaster, PA
Yeah... I can't wait until it's clear... almost there... probably another week or so and it should be good to go. Then I'll remove that huge concrete block from the deep end. There might be a cut in the vinyl liner... is there a patch kit I can use to patch the hole? I vacuumed more stuff from the bottom and it's getting cleaner and cleaner... I can finally see the main drain in the deep end. Thanks everyone for your help... much appreciated.
Kamil
45
Lancaster, PA
Here is a new pic
It's pretty much good to go... I still need to vacuum the bottom again and then dive in and try to pull the huge block out.
Kamil
45
Lancaster, PA
I think the pool is good to go. I tested FC last night it was 4.5 and this morning it was still 4.5.
TA 90
CH 230
pH 7.4
Kamil
45
Lancaster, PA
Thank You. I'm very happy with it. I'm surprised it was not that hard to do. When I first saw the pool I really thought I would need to drain and refill the pool.
