- May 27, 2019
- 1,621
- Plaster
- Hayward Aqua Rite Pro (T-15)
I noticed pressure, (any pressure!), maybe 1.5 psig, on my filter at 1050 RPM. I looked at the VSP and the power had increased as well (68 Watts vs ~55 Watts). I thought it was time to clean the filters. I found my "old" filters and decided I needed to do a soak on those before using them.
I ended up just cleaning my pool filters and putting them back. They were not too bad. My spring filter cleaning was BAD. I do not know how long I went, but they actually smelled! Like dog poop!!!
I was reading through some of the filter cleaning threads. I like the idea that as long as the pleats are in good shape, you can fix the rings with hot melt glue.
See below. Lots of bug parts and magnolia blossom parts. I expect I will be getting less "sand" from my sandstone/flagstone. The pool robot is picking that up instead of just flinging it around in the water.
Here are my old filters which have been in the garage for a few years. I decided I need to soak these first. I 1/2 filled the trashcan and used "Power Soak", only because I had it on hand. It suspiciously smells like old dishwasher detergent. I'll flip them after an hour. I already see some white Crud coming out of the filters. If they clean up well, I may swap these into the pool and then soak the ones that have been in service.
