Hey TFP! I have some significant calcium scale build up on my tile (see below pics - its the white haze at the top which forms an arched pattern half way down the tile). My tile is a grey natural stone (looks like slate) with a pretty matte finish. I called around and 1) can't find a pro to do it and 2) was told by one guy that everyone is so busy and understaffed that if I do find someone to do it I probably should not trust them since its really labor intensive and requires manual scrubbing with mercuric acid and if they have the time they probably aren't that good at their job....
I also have read about soda and bead blasting but finding someone to soda blast in Charlotte is proving difficult and I don't really want to drain the pool.
Sooooo, this is what I am thinking about: Using an air powered sander (something like the attached pic) with some waterproof sandpaper and a squirt bottle of mercuric acid. I started working on the scale without the sander, just using hand sanding and acid (and rubber gloves!) which got results but it was way too labor intensive . So my questions are:
1) Is this going to do more harm then good? My fear is I am probably scratching up the surface of the tile in the process of cleaning it which likely makes it more susceptible to scale in the future.
2) Is waterproof sandpaper the right thing to use? I was using 220 grit - I might start with something finer to see if it works. Or are there polishing pads that might work better?
3) When I was experimenting with hand sanding I was using full strength MA, misting it on the tile, letting it sit for a few minutes, and scrubbing off. Apart from any risks to my skin/eyes (I wore plenty of PPE and suffered no ill effects) is this going to catastrophic damage to my grout and cause tiles to fall off? The pool guy I talked to recommended 70% MA dilution. I just cant imagine it being on the grout for a few minutes causing that many issues but maybe i am wrong....
4) Anyone had luck with the chemical scale preventer as something I could apply after the removal to prevent future buildup?
