I have a pressure side cleaner, Letro Legend pool cleaner. Recently it started to show the problem that the rear side does not touch the ground, no matter the booster pump is running or not. Looks like some air was trapped inside the cleaner. Also I noticed that backup valve was stuck in backup mode with water shooting out the valve constantly. I plan to replace the backup valve. However, I am not sure whether the dysfunctional backup valve caused the floating issue. Have you guys seen the same issue? Any suggestions are welcome.
