Cleaner will only move backwards
rphpool
513
Sugar Land , TX
You can take it apart ( YouTube vid to show you ). The backup valve may be clogged. Is it in warranty? If so call Pentair, they will send you new parts or have it serviced.
rongcon
2
Plano/TX
All valves are cleared - no clogged. During the clean mode with booster pump active, the water jet sprayed in the front instead of from the rear. Which mechanical part determine of water flow via incoming water pressure?
rphpool
513
Sugar Land , TX
Good thread to read
Timer reverse valve
