Cleaner turning on/off on its own
PanchoButler
Active member
Aug 29, 2019
40
Katy, TX
I installed an updated card into my main Easy Touch to be able to run new LED lights. Since installing it, my Pentair Racer turns on and off on its own when the main pump is running. I can shut it off with the easy touch, and 10 mins later it will be back on. Kind of annoying when you are swimming and it starts running into you.
Any idea what could be causing this?
thanks
Jimrahbe
16,912
Bedford, TX
PB,
I suspect your ET is programmed to do what it is doing...
Why did you have to get an updated card? Where did you get the updated card? Was it used?
Do you have ScreenLogic? If so, can you show me your set up page like the one below..
