CL Industries Quartz Question
josh1014
1
Maryland
Hello all,
I have been doing research on quartz pool finishes for my new pool. My builder likes to use the CL Industries product lines. I have been comparing Sunstone Select, Sunstone and Krystalkrete.
I’ve read the blurb on the company website: “SunStone and Krystalkrete use the same sized aggregate called T-Grade while SunStone Select uses a smaller aggregate called S-Grade”
I have some samples of each and the Sunstone Select does feel a lot smoother and less abrasive compared to the larger aggregate in the Sunstone and Krystalkrete products.
I plan to use my pool for water volleyball. I will also have a sunshelf for kids to play, likely with their knees down on the plaster finish.
I have a friend with a pool that used Sunstone Select, so I know that product is smooth enough to not irritate your feet with sport activities. The problem is I do like the color selection a lot better with the Krystalkrete line, and would like to go with it, but I am worried that I can’t risk going with a more abrasive finish.
Does anyone have any practical experience to share with these products? Thanks!
kimkats
43,273
Tallahassee, FL
I have a liner pool so no personal input BUT have read here quite often about how smooth the smaller pebbles are. If you want a REALLY smooth surface go plain plaster. It makes a very pretty water color as well!
