Circupool swcg ?
JJU
13
Libby, Montana
So I’m looking into a swg for my pool. I am so confused on size I would need. I have an intex 16x32x52. With a 2800 gph krystal clear sand pump. I have went to their website and read about it. My brain is not getting it, please help. I would spend a Fortune on chlorine where I live. 14,300 gal pool we had our water tested ph 7.5, 19 grains (hardness) iron .5. That’s all the test tested for
proavia
1,858
Chandler AZ
We recommend a SWG that is 2 times the volume (in gallons) of your pool. So a 10,000 gallons pool would need a SWG rated for 20,000 gallons.
Mdragger88
632
Hernando, Ms
I calculated your volume to be 12083 gal-
The largest intex swg is rated for 15000 gal. If you’re worried that won’t be large enough you could add another small one later & have one on each return- that is the setup i have on my 27k gal pool
