Circupool RJ-60
joel A
1
ny
This is the 3rd season for this unit. Have had no problems until now.
The display keeps running through water temp, power, volts, salinity,
model,amps, etc. Has anyone experienced this?
Any suggestions?
mknauss
22,735
Laughlin, NV
Welcome to the forum!
Have not heard that reported before. First step I would do is remove the power from it and wait a few minutes and then power it back up. Also call Circupool tomorrow or Monday and report it.
Be sure to maintain your FC in target range by adding liquid chlorine.
I suggest you read ABC's of Pool Water Chemistry and consider reviewing the entire Pool School eBook
wireform
In The Industry
Aug 15, 2017
518
Spring Valley, NY
I would recommend shutting off the power to it via the circuit breaker and turning ON the power switch of the unit to bleed off any juice left on the board.Then power it back on to see if it changed anything.
