Hi!
I'm having a problem with my CircuPool RJ+ SWG cell leaking at the seam where the cable attaches to the cell.
(see Attached photo)
Questions:
Questions:
- Can this cover be opened by me to try to find out where the leak is?
- If yes, how do you do it without destroying it?
- If no, Can I use something to seal over the seam to stop the leak? Epoxy, Silicone, or LB Weld?
- Will sealing the leak from the outside cause wiring /shorting out problems on the inside?
