My unit will be here tomorrow but my pool is still closed with a water temp of 55°. I will mount and wire the box and plumb the cell using the bypass cell in its place when it arrives. I plan on opening the pool on Friday and start getting the balance right and let some sun hit the water to start it warming up.
Anyway, its going to be sometime next week at the soonest before I bring the SWG online and I have a question that requires it to be powered on to answer. What is the control box's status when power is applied? Does it come back on in the last state it was in when powered off or does it come back on and start generating? I ask because I often use a fountain at night during the dog days to cool the water and wonder if I am going to have to remember to turn the SWG back on in the morning when the timer hits "on" time again.
I just thought of another question - will it harm anything for the control box to have power without the cell connected? As stated above I plan on wiring it tomorrow but the cell won't be plugged in for some time. Should I use a plug instead of direct wiring to the timer as I had planned?
Thanks
Edit: "Should I use a plug instead of direct wiring to the timer as I had planned?" Beings I will be bringing it inside for the winters, I would say "Doh - Yes!"
That leaves only the bonding wire to disconnect.
Thanks
