Chlorine tablets "pucks"
Raaron
18
I know most of you use the bbb method. I have heard some say they use them when they go on vacation. Are there any reasons for not using them besides CYA? Do they put other stuff in the water besides chlorine and CYA?
Andrew Sarchus
Active member
Apr 11, 2011
31
Seattle
The ones I see at Walmart and Costco both contain copper which will build up and cause staining.
JasonLion
Platinum Supporter
Trichlor tablets add chlorine, add CYA, and lower PH. Adding CYA is great when your CYA level is low, and can be a serious problem when CYA is already high. Likewise, lowering PH is great if your PH is high, and quite annoying when PH is low. As long as you are aware of what your levels are and either need or can compensate of the other effects, there is no problem using trichlor tablets. For most people most of the time, CYA eventually gets too high and you have problems.
Raaron
18
Does the cya slowly go away or eventually go away. I have Leslies tabs and it doesn't say they contain copper but that doesn't mean they couldn't.
Richard320
22,069
San Dimas, CA (LA County)
There have been reports of CYA mysteriously vanishing, but it's so rare as to be newsworthy.
CYA only goes away by draining or splashout.
Isaac-1
6,711
SW Louisiana
CYA can go away, but not in a controlled way, and is often associated with bigger water problems. I had an incident a few weeks ago where nearly all my CYA disappeared in during an algae bloom. This was caused by my chlorine metering pump failing the one week I was out of town letting my FC drop to 0, I came home to find somewhat cloudy water and a stopped up DE filter. Before the incident my CYA was in the 20-25ppm range (indoor pool), I ended up adding enough CYA to boost it by 20 ppm (the test only reads down to 20 ppm), a couple of weeks afterward my CYA tested out at 25-30 ppm so I am estimating that during the algae bloom my CYA dropped to under 10 ppm. (note it can take over a week for powdered CYA to fully show up on the test from the time it is added to the water)
Ike
257WbyMag
5,061
Denton, TX
The HTH/Pace brands do add copper to their tablets.
