Chlorine smell
kmoore392
Active member
Jun 13, 2017
32
Surprise Arizona
#1
I finally received my TF-100. Been testing all week to get a feel for the pool. I know I need to partially drain to bring CYA down. But I am smelling a hint of chlorine.
According to the math, CYA 125 X .075 my chlorine should be 9.3 or no lower than. BTW.. I'm no longer using trichlor pucks just 8% bleach and 10% liquid chlorine.
Also I let the PH run high so I could put enough MA in to drop TA down. Just did that this morning.
Any idea why I'm smelling chlorine?
About draining.. is there any math out there to calculate how long it will take to fill the pool given psi, size and length of hose? I have access to 3 bibs all between 25'-100' away from the pool.
FC-12.5
Ph-8.2
TA-120
Cc-.5
CH-200
CYA-125
